master cylinder
Car: 1990 Formula
Engine: 5.7 liter
master cylinder
ok, i dont know if i have a slow leak somewhere or what but the other day i noticed that my brake pedal was going all the way to the rear of the floor when braking and it was poor braking at that. so, i filled the resavoir in the master cylinder with brake fluid and noticed the compartment closest to the firewall was almost bone dry. I filled it up (maybe over filled) and pumped the brake pedal and it got better. (didnt have time to bleed the brakes, I was on my way to work) and later the next day, i stopped to get gas and I had smoke coming from the hood. it seems like that i have a leak somewhere at the master cylinder and it was leaking down to the exhaust mani and thus causing the smoke. i have yet to see puddles of brake fluid on the ground so does this mean that i am losing the fluid at the M.S. ? has this happened to someone else? where does this thing prone to leak at? any help is appreciated. thanks
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
I have experience...unfortunatly,its a result of bad judgement.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had a leaking Master Cylinder, it was an easy swap. But then 6 months later the resevoir kept getting low. I then changed the resevoir gasket and that fixed the problem.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
Car: yep
Engine: uhuh
Transmission: sure does
The master could be leaking down the booster. Remove the 2 hold down bolts on the master (don't disconnect any lines) and lean it foward to look behind it into the booster, if there is any fluid, the master is no good.
Could also be a leak just about anywhere in the hydraulic system of the brakes.
Look at lines, wheel cylinders, etc. Pull the boots on the W/cylinders back and see if fluid comes out.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Just a Note, personally When I detect something awry with My Brakes, I take the Day Off and Fix it.
That And Leaking Gasoline.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
