compresion ratio?
Old Mar 6, 2001 | 11:40 AM
mustangs killer's Avatar
compresion ratio?
How do you figure out the compresion ratio useing a compression tester. Thanks
Old Mar 6, 2001 | 01:40 PM
GOLD85's Avatar
you realy cant. differnt cams produce differnt cyclinder pressur. a cam with low duration will pruduce lots of cyclinder presuer and have lots of bottem end torque. a high duration cam prduces less cylinder pressuer cause the valves are open longer and bleads off more cylinder pressuer, so you need high compresion pistions to raise your cylinder presuer so you dont have a soggy bottem end. hope this help
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
