Replace fuel pump, still nothing
Car: 88 IROC
Transmission: auto
I worked for about 10 hours today replacing my fuel pump, i got a new one (190 ltr/hr). The reason i changed it is because i put a test light to the wire that goes into the fuel pump(behind the back seat, underneat the carpet) and it lit for about 2 seconds when i turned the ignition on - just like it should. So i figured there is nothing wrong with the fuel pump relay or anything else electrically. After i put the new fuel pump in, i still don't hear it run. My question is, even though my test light turns on when it should,(right next to the gas tank) could there still be something wrong with the relay or something else that is causing my fuel pump not to come on? I am so mad, cause i think i just worked 10 hours and spent 80 bucks for nothing.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears, slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
Car: 89 IrocZ
Engine: L98-ish
I think there's also a fuel pump ground close by, follow the wire and make sure it bolted down to clean sheetmetal.
Also, make sure the ground strap from the block to the firewall is intact and good.
Next, unless you've got a real good eye with the light, use a volt meter on the line and make sure you have 12.5 or so Volts when you turn the key on.
My guess is lower than normal voltage, or a fuel pump grounding issue.
Car: 88 IROC
Transmission: auto
I checked the voltage w/ a voltmeter and i was getting about 9volts +/- .5 I have to find the ground wire now, do you guys know where it grounds to? thanks for your help
Car: 88 Firebird WS6
That voltage sounds very low for a car not started. It will drop even further when the starter kicks in. Theres a wiring problem somewhere, maybe corrosion or a fauly relay/bad ground.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
Car: 88 IROC
Transmission: auto
Ok, i give up, i tried my best to figure out what the wiring problem might be. I just connected back my shocks and put the tires back on and gonna get it towed as is. The shop can deal with it from now on, i don't think its gonna be that expensive anymore since i got the exhaust out and everything. Thanks for trying to help me out, i'll let you know what was wrong with it.
Car: 88 IROC
Transmission: auto
I Got it back from the shop already!! I guess it wasn't the fuel pump after all. You guys were right, it was a ground wire that connects to the battery. All is well now. Just wish i had it checked out sooner before i replaced the fuel pump. At least i put a higher flowing pump in there so all that work wasn't for nothing afterall. I'm just so damn happy that its working right now. I missed driving it so much.
p.s. It sounds soooo good without the exhaust on the car.
92camaroJoe
Aug 13, 2015 06:07 AM
