Knock Diagnose
Old Apr 11, 2004 | 05:57 PM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Knock Diagnose
Hallo to everybody !
Sometimes I can hear a knocking sound from under the hood, but I canīt figure out the cause. Itīs most of the time when shifting from N or P into gear, but not always. When idling in D it sometimes occures, too, but not while cruising arround ( at least I canīt hear it then ). MY motor has about 3k miles on it and the oil pressure is quite low at idle ( I hope itīs the sender, cause the needle sometimes goes up and down without changing the rpm, Iīm going to replace it soon ). What would be the sound of a rod or main bearing going south, wouldīt it knock all the time ? Valve train noise perhaps ? - But why intermittent ? - Iīm rather clueless, perhaps you can give me a hint. ( I hope my rebuild engine isnīt in serious trouble ?
Thanks,
Uwe
Old Apr 11, 2004 | 06:26 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Could be the transmission mount, since it happens when you shift into gear.
Old Apr 13, 2004 | 01:33 PM
Car: 1985 IROC-Z28
Engine: TPI 350
Shouldīt be the transmission mount right under my bottom ? - Why does it knock under the hood ?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
