compression test results
Old Mar 6, 2001 | 08:27 PM
mustangs killer's Avatar
I ran the compression test and the results are between 180-190 lbs. does anyone know about what compression ratio this is. Thanks
Old Mar 6, 2001 | 08:40 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Looks like you've got good compression, assuming all your cylinders were within 10 lbs. Don't be confused though--cylinder compression has nothing to do with the compression ratio. You'd have to tell us what engine you have before we'd know the compression ratio. And that's assuming the engine is stock, meaning no aftermarket heads, pistons, or milling.
Old Mar 6, 2001 | 09:53 PM
355cid engine heads are world product s/r torquers 67cc, .125 domed pistons. does this help?
[This message has been edited by mustangs killer (edited March 06, 2001).]
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
