Is Speed-Motive's Streetmaster 383 shortblock a 1 piece rear seal?
Old Mar 6, 2001 | 07:12 PM
Mike92's Avatar
I went to speedmotives site and there 383 Streetmaster shortblock is only $1300 but it doesn't say if it's a late model one piece block or not. There email doesn't work either. Thanks
92fb currently a TBI 305, (hold the laughter to a minimum). Going to be a 350 carb with 350HP and 400FT/Lbs.
Old Mar 6, 2001 | 08:58 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I can't answer your question, but I did want to say something.....PLEASE don't purchase a motor from these people. They are absolutely terrible people to have to deal with when something goes wrong. Trust me on this, I made the mistake of buying a short block from them last winter. The motor ate the crank up in 4000 miles due to the fact they never align bored the mains. That was one of the major mistakes they made, there were other minor ones too. I'm not saying that every motor they build is a bad one, I am saying if something goes wrong with the one you buy.....you are effed!! Don't make the same $1800 mistake I did. If you can, I would definately deal with someone local and that has a good reputation....it may cost alittle more, but in the long run it's worth it.
Old Mar 6, 2001 | 11:15 PM
Mike92's Avatar
I was leaning toward a stock L31 shortblock from Scoggin Dickey. Thanks
Old Mar 7, 2001 | 02:34 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I agree with 406TPI. I know two people who got bad engines from SpeedoMotive.
And for that cheap of price, it has to be a 2-piece seal and non-roller cam.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
