Engine quits on hot days
Old Mar 6, 2001 | 06:59 PM
CBernard's Avatar
After engine gets hot (op-temp) it quits. After it quits it will start up but wont keep running. after it cools down I can start it and drive for about 1/2 an hour before it quits. In the evening it seems to work fine. :no codes, new injectors, new computor, new plugs, wires, cap, rotor button, coil, ignition modual. Fuel pressure is 46psi at idle. I haven't been able to check it when it dies. Car is an 87' GTA 350 TPI 15000km on engine. PLEASE HELP
Old Mar 6, 2001 | 07:48 PM
leirch's Avatar
How many miles does the car have? Or more importantly, the engine. If it has a TON of miles it may be the distributor itself. Possbily the pickup coil on the base of the distributor could be going out on you.
Just some thoughts,
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Mar 7, 2001 | 09:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, it does sound like the 'ol bad spark module problem... but you replaced it already? Maybe you got a bad one? Did you use that white heat-transfer gunk between the module base and the distributor? And like leirch said, replacing the pickup coil's a good idea too (unless that's the coil you were talking about).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 7, 2001 | 05:20 PM
CBernard's Avatar
The coil I replaced is the ignition coil. The car has 126000km on the body. The engine was a complete rebuild including new crank, bearings, rods, and pistons. Bore .030" over
with 10:1 flat tops. Reason for rebuild was a rusted oil cooling line blowing at 5000rpm, and with digtial dash, t-tops out, and a bright sunny day made it hard to see the oil guage. Thanks for the tip on the pick-up coil I'll try it.
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
