Interesting Idle
Old Apr 13, 2004 | 05:04 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
Interesting Idle
my car has been idleing weird for a few weeks now. after it's warm and i come to a stop light or stop sign, the rpms will drop to about 1200-1500, stay there for a few seconds, then slowly work it's way under 1000 to where it normally idles around 700 or so. it's not setting off the check engine light so i don't have anything to check. i looked to see if the throttle cable was sticking, but it snaps right back into place no problem. the only thing i can think of is i changed the clutch like a week before, could that be doing it. it's a centerforce dual friction clutch and pressure plate with the centerforce throwout bearing (if it means anything to you). is there anything else i should take a look at? thanks in advance.
Old Apr 15, 2004 | 08:12 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I have litte experience with TBI, but...
on my TPI setup, I have a sensor called the IAC (Idle Air Control).
When mine was full of carbon and compressed (really not a good thing), the car would idle poorly and the tach would jump. But when I drove down the road it wasn't bad. This sounds similar to what you are explaining.
More than likely, your TBI has this sensor or one similar. I would check it to make sure it is not compressed and/or full of carbon.
I believe, for TPI, you can buy a new one at Autozon for about $50.
Hope this helps.
Old Apr 15, 2004 | 12:55 PM
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
I agree, sounds like what my TBI s-10 did, it threw a code for the IAC after it got really bad. Price was around $50 for the TBI unit too.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
SlowAZ28
Sep 2, 2015 05:19 AM
Dialed_In
Aug 20, 2015 01:45 PM
ezobens
Aug 19, 2015 10:29 PM
