Trans doesnt want to shift
Old Apr 15, 2004 | 06:32 PM
BryceW25's Avatar
Car: 87 Z28
Engine: Mini Ram II, 113 heads tpi
Transmission: 700-R4
I installd a new intake and i am haveing problems with the trans., when im just driving normal, easy on the gas, it with rev high and then shifts real hard. whats my problem please help
Old Apr 15, 2004 | 07:00 PM
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
your problem is the kickdown cable that runs from the transmission up to your throttle. I've never adjusted it on a tpi but I believe it's the same as on a carb. Just push in the button on the cable and then press the pedal all the way to the floor. Do this then go out and drive it, if it's not how you like it just do it again. For some reason those things allows get messed up when you unhook them.
Old Apr 15, 2004 | 07:07 PM
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
sorry the cable is called TV (throttle valve) cable. Heres a great thread with lots of pictures to help you out.
https://www.thirdgen.org/techbb2/sho...hreadid=234918
Old Apr 15, 2004 | 08:58 PM
BryceW25's Avatar
Car: 87 Z28
alright ill try that thanks
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
