Electric fuel pump with carb?
Old Apr 15, 2004 | 06:56 PM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Long time no post.... but anyways.
This summer I plan to go through my fuel system. The car is a 1979 Monte Carlo, but the reason I ask here is because of all the fuel injected cars.
The plan is to use a factory intank electric pump in my baffled Grand National gas tank. I'm curious if there is a factory style intank pump that could not only put out enough fuel for a hot small block, but not complain about being regulated down to 6-6.5 PSI. Something along the lines of a pump for a TBI 350 or 454 came to mind, but not sure on that.
I apologize if this is a beat-up subject, but it seemed like a good alternative to a sump, and thoughts on it are nill within the G-body crowd.
TIA for any thoughts.
Old Apr 15, 2004 | 07:00 PM
ede's Avatar
ede
i'd think any tbi pump would work ok. i'd stay away from tpi pumps
Old Apr 15, 2004 | 07:40 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A Walbro pump with a regulator that has a return port should work well.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
