Who has hit 12's with a TBI-Carb swap W/ stock F-pump?
Old Mar 7, 2001 | 08:47 PM
Mike92's Avatar
I would like to hit low 13's or so with my TBI-Carb swap and was looking for some ideas. So far my idea is using my 305 Torquers heads, unshrouding the valves, porting them, ZZ4 cam, 9.5-1 compression, 625cfm demon, Holley Projection intake modified for carb, TES, 3.42 gears, and posi. Would I be able to take LT-1's and keep up with Ls-1's light to light?
Old Mar 8, 2001 | 01:10 AM
burnoutrpm's Avatar
it'll be some interesting races... the ls1 in peticular!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 8, 2001 | 10:00 AM
marc91383's Avatar
Sounds like fun.
As far as the fuel pump in conerned...I'm swapping out my 305 TBI with a carbed 383 and I'm leaving the stock pump in the tank with a pressure regulator to make the carb happy with about 6 1/2 PSI. Should be interesting to see if the pump can keep up. If not..I guess I'll have to replace it.
BTW, the 383 will be running about 10:1 comp, Dart Iron Eagle heads, Hyd roller cam, dart Kool can intake, Holley 750 DP, Turbo 350 w/3000 stall, 3.73 posi, SLP 1 3/4" headers, 4" mufflex
Old Mar 8, 2001 | 04:41 PM
Mike92's Avatar
I was debating weither or not to get the LT4 Hot cam instead of the ZZ4 cam but I think the Hot cam would lose too much lowend, I really only want a light to light car. I don't plan on running an entire 1/4 mile too often. Just jump to a little over the speed limit, Quickly.
Old Mar 8, 2001 | 08:00 PM
gruveb's Avatar
Car: 1989 IROC-1
Perhaps try the comp cam 12-238-2......I don't know, just throwing that out there. That's what was highly recommended for my L69, and also what Car Craft put in their 325 HP LG4. I've not finished mine yet, but I'll certainly let you know how it goes. I'm adding headers, holley double pumper 650cfm, and a Weiand 8004 intake manifold. Probably not as wild as yours, but all I'll lack is the heads!! I've already got the 9.5:1 compression.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
87camaro87
Sep 9, 2015 10:29 PM
