What makes vortecs S/A?
Old Apr 16, 2004 | 12:23 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Ive got some vortec heads. My question is this: They are self aligning, yes. But what exactly makes them self aligning? Is it the fact that the valve tip protrudes higher above the locks/retainers than normal, non S/A heads? Im assuming they are standard 11/32" valves. If so can i just toss in any old 11/32" 1.94/1.5 valve and be good? Im planning on using comp/crane/manley/etc.. hardware. After its all said and done, will they still be self aligning?
And is there any way to make them so that "normal" pro mags will work? like pro mags for perim. bolt valve covers? I know the screw in stud/guideplate stuff already.
I guess my ultimate question is: what makes them self aligning and is there a way to change that?
Old Apr 16, 2004 | 02:37 AM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
If you install studs/guideplates and hardened pushrods, then you got everything needed for NSA rockers. You can also use "ordinary" valves or stay with "higher" tips which work OK with both types of rockers; shorter ones are not so universal because they don't allow s/a rocker tip to "engage" properly.
One thing you have to consider is little tweaking of centerbolt valve covers or using taller ones for clearance with Pro Magnums.
Old Apr 16, 2004 | 08:00 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
self aligning heads dont have any method machined into them to hold the pushrod still... so the rocker is what keeps the pushrod there.
with non self aligning, you have guideplates, or machined holes in the head holding the pushrod (and therefore the rocker) in place.
if you add some guideplates to your vortecs, you can run non self aligning valvetrain components..... but you CANNOT run self aligning rockers AND guideplates.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
Fast355
Dec 2, 2016 06:33 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
