familiar with LT-1???need help
Old Apr 16, 2004 | 11:27 AM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i have a friend that own a lt-1 in a caprice 9C1 that has the 4,3L v8 engine in it before and i would like to get his injector to upgrade mine(18lbs 305 tpi now 350tpi) how do i know if the are from the 95 camaro lt-1 engine or 4,3v8 engine??? they are black hole in center seems to be bigger and the code ritten on them are not GM part number.
what should i do??
Old Apr 16, 2004 | 09:28 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
If your friend has a 4.3L in his Caprice he doesn't have a LT1, he has a L99.
The L99 has 19# fuel injectors stock. The number stamped near the top will be 17120683.
Old Apr 17, 2004 | 08:13 AM
FOX-GTA_89's Avatar
injector number
he buy the caprice with an lt-1 out of a camaro but it was a 4,3 originally so did'nt know if the guy swap them too
A-0294-17121068 witch one are they?
they seems shorter than my tpi one will they fit?
im swapping 305 tpi to 355 tpi and my stock 18 psi wont run it
i think the stock 1995 camaro injecton are 24 lbs true?
Old Apr 17, 2004 | 01:03 PM
Engine: 4.0L
Re: injector number
Those are '95 LT1 injectors, 24 pound rated.
Old Apr 17, 2004 | 01:18 PM
FOX-GTA_89's Avatar
lt-1 new injector seems shorter than tpi will they fit??
Old Apr 18, 2004 | 08:31 AM
Engine: 4.0L
They will fit, there are hundreds of people running LT1 and even Ford injectors in their TPI.
Elephantismo
Feb 13, 2019 12:51 AM
no green
Mar 3, 2016 05:19 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
buckeyecelt
Sep 24, 2015 05:50 AM
