305 heads on 383 stroker???
Old Apr 17, 2004 | 03:54 PM
beerfish89's Avatar
I have the heads off my original tpi 305 and was wondering if they would be suitiable for a 383 after a little work. Doesn't sound like a good idea logically but was hoping to cut some corners
Thanks for any advice
Old Apr 17, 2004 | 04:04 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
They'd work, but there are a lot better alternatives. You'd make more power of spending the stroker money on good heads for a 355 IMO.
Scoggin-Dickey has Upgraded Vortec head kits which include assembled Vortec heads (featuring high performance Z28 valve springs with light weight LT4 retianers; good for about 0.550" lift with a hydraulic camshaft), head gaskets, head bolts, rocker arms, Performer RPM intake manifold, intake gaskets,12 point intake bolts and additionl required components as stated for $900.
http://www.sdpc2000.com/cart.asp?act...2174&pid=89534
That would be an inexpensive alternative to high dollar aluminum heads which would allow you to make substansially more power than your 305 heads.
What exactly are your plans for this engine?
Old Apr 17, 2004 | 04:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
you can use them but as stated its probably not worth it. you would have to do some porting, new (bigger) valves, etc to make them support a 383. the only thing they are good for at this point is raising compresson.
Old Apr 17, 2004 | 04:22 PM
beerfish89's Avatar
I'm not wanting any thing crazy just enough to bust the stangs around here. I gonna use my existing 305 tpi setup and burn a custom prom. Just trying to figure out the direction I need to go cam, injectors, heads, ect. It may see the strip once or twice.
Old Apr 17, 2004 | 04:31 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
So you have a roller cam block? How much power would you like to make? More importantly, how much money are you willing to spend?
Old Apr 17, 2004 | 04:50 PM
beerfish89's Avatar
I think it is a 90 model 350, a close friend of mine dad ownes a machine shop and he said I could get the block (I haven't accually seen it my self). I think he wants to trade for my 305 block because thats what all the dirt tracks around here run. Anyway, as far as power, in the 305's better days was pretty impressive, but after 5 years of my driving she developed a nasty knock. So I figure since I am going to rebuild I might as well build a stroker motor. I figure that I need to get a cam that makes peek power around 5500 rpm if I can get the tpi to coropoate. Get my heads or different ones fixed up and see what I get. It will have to have more power than the 305. I hope to spend around 1500, but expect to go around 2000 but not much more than that.
Old Apr 18, 2004 | 01:07 AM
onebinky's Avatar
The 58cc chambers will raise your compression, but the small runner volume will choke the motor out of any decent kind of power.
You're better off just sucking it up and getting something better suited towards what you want to do IMHO.
Good luck
Jake_92RS
Jan 28, 2020 10:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
