Tranny making strange noise past 3k while in gear
Old Mar 8, 2001 | 09:50 PM
theformula's Avatar
Only happens when the car is at operating temperature and the tranny is warmed up enough. The clutch is brand new by the way and the T-5 tranny is the stock one.
I rev it past 3 k when in gear and the shifter handle rattles like crazy and the car makes this grinding type noise. It keeps making the noise until I put the car in neutral. And if I rev it past 3k in neutral it doenst make the noise. Could it be the synchros? It also grinds into 2nd sometimes
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (4700rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited March 08, 2001).]
Old Mar 9, 2001 | 08:58 AM
ede's Avatar
ede
well i'm no expert but i pretend to be one on these boards. i'd be dropping the trans and/or having it checked out before it gets worse. not very often you'll find a noise or problem get better or fix it's self. i'd say gears,shift forks, or what ever controls the thrust in a t5, i've never had one apart to know.
ICON Motorsports
1st & 3rd
Old Mar 9, 2001 | 07:46 PM
84FTA's Avatar
Hrm. Well, we can pretty much rule out the syncros and shift forks because it's already in gear. The last two ideas I have are.....
Low fluid (hopefully refilled correctly on clutch replace)
and the dismal....
Stretched case causing a mis-meshing of gears. As with most things in the drivetrain, the faster they move, the more exact the clearences need to be.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Bigold4x4
Sep 28, 2015 05:21 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
