Hydrocarbons failed at Idle Y?
Old Apr 19, 2004 | 06:25 PM
jdrafke's Avatar
Well i too kthe car in after replacing the o2 sensor ,cts, new air filters, pvc, tps set at .54, timing set at 2* advance(dont think thats the problem), doesnt blow or smoke any oil. Car did much better then last time, Standard HC is .80 and co is 15.0
First: HC 2.00 and 11.9Co
Second time: HC 1.04 and 3.4Co
From the looks of the graph the HC spiked over the limit mostly at idle and slow rolling speeds. After that the HCs stayed down under the limit. I have noticed that the car does idle rough at times and can be pretty bouncy on sumdays. Any ideas on why it might not be passing, I only got one try left!
Old Apr 19, 2004 | 06:34 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hc's can be caused by misfires. Whats the condition of your plugs, wires, cap etc.
Another thing to check since your problem seems to happen at closed throttle is the iac. It may just be dirty you can try to clean it out with some carb cleaner.
Old Apr 19, 2004 | 07:12 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Remember the thread in TPI forum? Arr/rich condition? I detailed some good testing information. I never heard back from you.
Old Apr 20, 2004 | 12:41 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Retard your timing 2 degrees and put 5-6 bottles of dry gas in the tank. The hc's should improve.
Old Apr 20, 2004 | 01:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ditto
Old Apr 20, 2004 | 05:06 PM
jdrafke's Avatar
Yea i already dropped some dry gas in the tank on the last run. It improved significantly but i know thiers a problem with the car if its having this hard of a time to pass. In the morning like i was aying the idle jumps up and down until it warms up The idle is still ruff even after its warmed up but it stops stumbling nad hesitating. U guys think it could be the idle air control valve? If so could this be causing me to fail?
Old Apr 20, 2004 | 06:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"Yea i already dropped some dry gas in the tank "
You don't want some, you want allot.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
IROCtometal
Sep 20, 2015 11:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
