noise from trans?
Old Mar 10, 2001 | 09:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
noise from trans?
last night I was racing an ls1 Z28 and he started to pull away wich is odd but, I decided to run him again same thing happened then, when I was comming to a stop I heard a noise like as if my out put shaft on the trans was just slopin around in the trans. so I spent a good amout of time trying to figure out if it was really the trans or rear end or ujoints. so tired and pissed I put it in the garage then to day I went out and jacked up the rearend of the car and have a look and see. the ujoints looked good and I put it in nuteral and spun the drive shaft and I could not hear any thing. so I sun the rear end still nothing gettin pissed now I secured the car sat (INSIDE the car) and drove it to a tire speed of 25 mph sliped it to N and listend still nothing drovit to 25mph again shut it off in N and listend still noting to make this long story shorter I drove the car and still found nothing. what could have it been and why did it go away over night? also this is a wc t-5 trans
Old Mar 10, 2001 | 09:25 PM
Vader's Avatar
88,
I've had tailshaft bushings that have been worn enough to start making noise when hot and under heavy loads, but the noise would disappear when the load was light or the trans was cold. You might want to look for excessive play there.
You might want to look at the torque arm bushings while you're there, and check for play at the input pinion of the diff.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 10, 2001 | 09:41 PM
Engine: ls1, LB9
it was strange because it sounded like a shaft rotating and it would decrease as speed decreased. very constant like a blown tire. do you think the ujoints are dry? Im sure if I spun a bearing in the trans it would sound like crap all the time and the shifter should have transmitted it to my hand.
Old Mar 10, 2001 | 09:43 PM
Engine: ls1, LB9
also how would I measure it? tail shaft side play?
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
