gas milage and fuel filter question....
Old Mar 10, 2001 | 06:19 PM
SAEspinz80's Avatar
i know this has been brought up before, but my 3.1 bird is only getting about 10-12 mpg in the city....i dunno if this is normal...but thats what i have been getting for the last year and half. my question i that i want to change my fuel filter...but i can't find how to do it in a chiltons manual. so where the heck is it and how do i change it?
1990 Firebird 3.1l
ASP underdrive pulleys
MSD GM blaster coil
MSD 8.5mm superconduter wires (custom)
Rapid fire plugs (gapped to .050)
Home made C.A.I.
GTS blackouts
Infinity Kapa 3-way 6x9's
Old Mar 10, 2001 | 07:03 PM
ede's Avatar
ede
if it's like all the other third gens i've saw the fuel filter is mounted in front of the rear end on the left side. takes a couple of wrenches. take off the gas cap before you start. buy a new filter before you start and you'll know what to look for.
ICON Motorsports
1st & 3rd
Old Mar 11, 2001 | 11:49 AM
a1987formula350cu's Avatar
It's not hard. the only hard part is threading in the new filter. Jack the car up from the back on the pumpkin and climb under in front of the drivers side rear whell. you'll see it. Cahnging it is common sense.
You should also look into changing your o2 sensor. This probably has the most effect on gas mileage. You'll find it on the ehxaust manuifold on the drivers side. The change is not hard but its tedious. You'll also need a special o2 sensor wrench. I got a bosch from autozone for about $20. Pep boys wanted $28 for a stock replacement so try to get the upgraded and cheaper bosch from autozone.
Good Luck.
1987 Firebird Formula 350[*]Stock except...[*]Cragar Street Stars
My Car Website w/ Pics
fyrebird350@hotmail.com
AIM/AOL: FIREBERD350
<<<<---THIS CAR IS FOR SALE(only 49k)--->>>>
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
