305 Block Strength/Power
Old Apr 22, 2004 | 12:16 PM
BadBird84's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.8l :(
Transmission: T-5 Five Speed
I was wondering, I am building a performance 305, as much of an oxymoron as that may sound to some of you. And I wondered since different years were rated at different HP and TQ, since I am putting all new parts in it, including pistons, crank, etc. if I should get one of the higher HP blocks or if it would make a difference. I also wanted to know if any years were more stout or durable than others. May be a dumb question, but try and help me LOL
Old Apr 22, 2004 | 12:29 PM
ede's Avatar
ede
blocks are all the same as far as 305s go, other than the one and two piece crank seals and roller cams.
Old Apr 22, 2004 | 07:09 PM
BadBird84's Avatar
Engine: 2.8l :(
Do roller blocks make any more power than solid?
Old Apr 22, 2004 | 07:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Roller block refers to the camshaft setup. The block will be the same cast iron whether its a roller cam or flat tappet, solid or hydraulic.
Old Apr 23, 2004 | 12:24 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Stekman
Roller and Non Roller blocks are not the same. Roller blocks are machined differently to accept a roller cam. You can make a non roller block work with a roller, but it takes some machining. Also roller blocks are one piece rear main.
Old Apr 23, 2004 | 12:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I did not say they were machined the same, i said they were the same cast iron material. The fact that the block may or may not be machined for a roller cam setup has very little influence on the amount of power that that engine can produce.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
