engine swap?
Old Mar 11, 2001 | 09:04 PM
virtual's Avatar
engine swap?
will a 350 from a 1977 impala fit my 83 z28 im taking out the 305?
Old Mar 11, 2001 | 09:14 PM
ede's Avatar
ede
all SBCs are the same size if thats what you're asking. there are no external differances. i don't think you have any ECM controls to worry about so it should be an easy swap.
ICON Motorsports
1st & 3rd
Old Mar 11, 2001 | 10:38 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Only one problem is if the heads on the 77 are not drilled/tapped for "7 bolts" on the ex. manifold mounting bolt holes.
Not all SBCs have the provisions for the stock ex. manifolds that use the outermost bolts on the pass. side.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
