People who have advanced timing....
Old Mar 10, 2001 | 06:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have a quick question. I thought the numbers were suppose to be on the dampener (the pulley behind the crank pulley) but I go to shoot the strobe light (timing gun) down there and NO NUMBERS! What the heck? Where are the numbers at so I can check to see what my timing is at?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Mar 10, 2001 | 06:58 PM
ede's Avatar
ede
the mark is on the damper, that you've found. the numbers are on a tab on the timing cover
ICON Motorsports
1st & 3rd
Old Mar 10, 2001 | 07:06 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Ok, I am confused. I have done it on the Fords and they had the numbers ingraved into the dampner and u just shot the timing gun at the dampner and it would show the number that way. Where am I aiming the gun this time? Do I make a mark on the dampner or something and see where on the timing cover to which number the mark shows up at? I am confused.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
[This message has been edited by 91Bird305 (edited March 10, 2001).]
Old Mar 10, 2001 | 07:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There will be a groove engraved on the dampner. I usually fill this groove with "white-out" (yeah, the office stuff) or you can use anything white. It helps the mark show up better w/ the timing light.
The "tab" is at the balancers 2 o'clock position and wil have numbers on it. The tab has notches cut into it, like a saw blade. The BIG valley is 0* then the peak of the first "tooth" is 2* then the next valley is 4* and so on.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 10, 2001 | 07:40 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
So how the heck am I suppose to measure white out going round and round?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 10, 2001 | 08:12 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Did you mean that as a joke?
You simply "paint" the groove and ONLY the groove, they way when you point the timing light at the timing tab, the groove on the balancer will show up better. If I confused you, don't paint the groove.
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Mar 10, 2001 | 08:15 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Oh Oh, I get it. ok. And then when it is standing still from me aiming it with the strobe light I measure where it is on those notches on the timing cover?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 10, 2001 | 08:16 PM
JETHROIROC's Avatar
LOL! Someone else that uses white-out besides me.
91- Well, you shouldn't worry about the white out going round and round since it generally "freezes" under the timing light, hopefully around the 6-8* notch. Just paint the groove on the dampener, find the timing tab GMTech mentioned, disconnect your ESC bypass, clamp the timing light lead around the #1 plug wire and the alligator clips to the battery leads, start the car, point at the "tab" and click! If you're like me, drink more Pabst Blue Ribbon and watch the flashing light for awhile. Kinda like a mouse on your computer but much more fun .
Old Mar 10, 2001 | 09:06 PM
steve8586iroc's Avatar
91Bird, you have a 305tbi, you will have to piont the timing light and look behined the water pump to find the timing mark. Belive me this stinks but what can you do but live with it.
Hope this helps.
Steve
Old Mar 10, 2001 | 09:23 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
not sure about the 91 cars but, most of the 88 with stock motors have the tab at the 2 clock position to the right of the water pump.
Old Mar 10, 2001 | 10:23 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JETHROIROC:
LOL! Someone else that uses white-out besides me. </font>
Jethro,
I'm sure I'd get accused of using Never-Seeze.
Don't forget to bypass the EST by disconnecting the single wire connector at the firewall.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 11, 2001 | 11:43 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
The only way to get my timing is looking in between the water pump and engine block also. It's an 89 TBI (used to be anyway). Just my .02
"Nothing is illegal till you get cought"
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Flowmaster
B&M MegaShifter
Old Mar 12, 2001 | 06:22 AM
SeanSullivan's Avatar
Oh it's illegal alright, but NO penalty unless you get caught.
gta892000
Aug 11, 2019 11:16 AM
Jorlain
Oct 8, 2015 01:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
87camaro87
Sep 9, 2015 10:29 PM
angel2794
Sep 8, 2015 06:22 PM
