ok heres the prob...
Old Apr 22, 2004 | 11:18 PM
popeyealica's Avatar
Car: 1991 chevy camaro
i bought a new battery and belt and alternator. but even when the key is on auxillary and the car is shaken the power seems to fade and when the car is started it doesnt seem to produce as much power as normal. im at witss end i checked the connections but cant find the problem. what else could it be?
Old Apr 23, 2004 | 10:55 PM
Vader's Avatar
Connections.
What kind of charging voltage are you reading at the alternator output stud? How does that compare to the voltmeter on the dash?
Old Apr 24, 2004 | 12:35 AM
AM Racer's Avatar
If shaking the car changes the available power, start looking for loose connections.
Maybe a missing or loose ground between the block and frame.
TA87GTA
Aug 26, 2011 08:43 PM
DrewsCam
South Central Region
24
Dec 16, 2010 04:49 PM
DrewsCam
Dec 15, 2010 01:23 PM
slickfx3
Aug 18, 2009 02:23 PM
hereinmissoula
Mar 26, 2009 03:25 PM
