My car's hard to start
Old Mar 11, 2001 | 07:50 PM
Tec21-CamaroLover's Avatar
When i turn the key it takes a while to start, i have to give it some gas too and it still takes several seconds. Probably 4-8 seconds. It's a Fuel Injection (Multi-Port) and yet I have to give it some gas. Before I got it it had been sitting for a while, (a couple of months) without being driven and I just gave it an oil change, changed the air filters, and gave it some of that fuel injector cleaner. On occasion it will start right away. That's about once in every 5 or 6 times.
'86 Camaro
2.8 MPFI
Old Mar 11, 2001 | 08:38 PM
JETHROIROC's Avatar
Have you done a fuel pressure test? Is it hard to start when warm or cold or both? Sorry about the questions, just need some more specifics to give you an accurate guess.
Old Mar 11, 2001 | 09:52 PM
I haven't done a test.
It's hard to start when it's warm or cold.
Old Mar 11, 2001 | 10:32 PM
JETHROIROC's Avatar
I would start out with new plugs and wires. See if that helps since your plugs may be fouled or just have worn electrodes. Check the fuel pressure too and see if it leaks down any, since leaky injectors can make one hard to start. Other than that, how many miles you got on it?
Old Mar 12, 2001 | 01:17 AM
My odometer says 260 000, approx.
I'm in Canada so i don't know if it's metric or not.
How do i check the pressure , and see if it leaks?
Old Mar 12, 2001 | 06:25 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
First of all if your car is fuel injected, which it is, you should not pump the accelerator at all when starting the engine. The engine has a computer controlled "Idle Air Control" valve that will regulate the air during start-up and the fuel is controlled by the computer also so pumping the pedal doesn't do anything to get more fuel in the engine to start it.
I used to have the same problem on my GTA but after changing plugs, wires, rotor and cap, and checked the timing, it did a lot better.
To do a fuel pressure check on the 2.8 MPFI is the same as the TPI engines, install a fuel pressure gauge on the Shrader valve located on the fuel rail(it looks like on of the air conditioning fittings), start the engine untill the pressure builds up to normal. With the pressure at normal, shut down the engine and see if the pressure on the gauge drops. If it drops your fuel pressure regulator is bad or your injectors are leaking through.
I do not know what the pressure reading is supposed to be for the 2.8, but you might get that from a local dealer service department.
Good luck,
Ozman
[This message has been edited by Ozzy88GTA (edited March 12, 2001).]
Old Mar 12, 2001 | 12:16 PM
86Trans Am's Avatar
Check the fuel pump. When it doesnt start, you might want to try turning the key to the on position a couple times to prime the pump, if in fact its the pump going out.
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
