a Couple of carb questions.
Old Apr 23, 2004 | 07:53 PM
no_car_yet's Avatar
my camaro has a 305 4bbl.
origionally a V6 car...the previous owner did the v6 --> v8 swap. and i think he may have not hooked up the carb properly.
with the car in park, and me revving it, the 2 big rear barrels of the carb do not open? not matter how much i rev it they don't open...
question 1: should the big barrels open when being revved in park?
question 2: if they actually should be opening, how much of a difference will it make when i fix it?
i understand these may be dumb questions, but i am new to carbs, so any help is apprieciated!
Old Apr 23, 2004 | 08:19 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
pleniums and carbs dont go together real well! Carbs usually set on an intake maifold,, is this the car in your sig?
Old Apr 23, 2004 | 08:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
No the "big barrels" won't open just by winging the throttle while in neutral. I'm assuming you're talking about the rear secondary air door on a Qjet carb.
The engine has to be under load at WOT , like when you're driving it.
There is a vacuum controlled delay diaphram on the right side of the carb that delays the air door from flopping open until the engine needs the extra air flow.
This momentary delay is nessessary to prevent the motor from bogging as the secondaries kick in.
You can check the air door spring tension by opening the air door by hand. You should feel light to moderate resistance as you operate the air door by hand.
If you want to test to see if the secondaries are working while you're driving it, temperairly wire the air door linkage shut so it won't open and go for a ride.
Find a book in your local Libary thats all about Q jet carbs.... The author is Doug Roe.
read it , know it......
There will be a test.........
Old Apr 23, 2004 | 09:17 PM
no_car_yet's Avatar
okay thanks for clearing that up. i seen the vacuum on the carb, but i wasn't sure if it was working....now i know that it will open at WOT under a load...
and to answer to first question, no this is not the car in my sig.
Old Apr 24, 2004 | 09:36 AM
Engine: 406
Then what he said....^^^^..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
tonys91rs
Sep 2, 2015 07:07 PM
