attn: VADER
Old Mar 12, 2001 | 11:12 AM
pat85yellowroc's Avatar
attn: VADER
vader, i appreciate your previous help. i was the one with the stripped oil pan plug. however, i have ground around the edge where it seemed to be welded and i cant get it to turn at all. i had the vise grips on there as tight as can be and nothing. if i grind the head all the way how can i still get the bolt out?? thanks in advance.
pat
beau-t-ful yellow 85 iroc
Old Mar 12, 2001 | 11:16 AM
Bort62's Avatar
time for me to be a bitch!
https://www.thirdgen.org/messgboard/...ML/006484.html
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 12, 2001 | 11:24 AM
well, actually everyones help ABSOLUTELY WOULD be more than appreciated. however, the only reason i applied to just vader, is because i was reffering back to a previous topic that he helped me on and i was unclear of what exactly he was saying. so, if you want to be a "bitch" than go ahead, but i am not looking for only the advise of one person. you could have maybe tried to help rather than being a ***** about it though. im sorry that it looked that i was relying on one specific persons knowledge because i wasnt. oh and hey, THANKS FOR YOUR HELP!
Old Mar 12, 2001 | 11:55 AM
gruveb's Avatar
Car: 1989 IROC-1
I read your last post, and this is a booger of a problem!!!-I feel for you. This is one of those things that makes you wonder why in the hell you would ever want to work on something yourself.
I suppose a complete oil sump change is out of the question since you are not keeping the engine?
I mean, you can spend an entire day grinding, drilling and tapping and not still not have a drain plug.
Or you can lift the engine swap it out, spend a day and have a sump.....
Old Mar 12, 2001 | 05:00 PM
SgtSkip's Avatar
Why not drill a hole, weld a nut, and use a bolt with some sort of o-ring as your drain plug? We used to weld in 1/2" pipe nipples and screw on 1/4 turn valves on our detroit diesels.
85T/A 305/QJ work in progress.
Old Mar 12, 2001 | 06:00 PM
ede's Avatar
ede
bort you beat me to it.
ICON Motorsports
1st & 3rd
Old Mar 12, 2001 | 06:02 PM
mtx28's Avatar
i cant resist.. if you read that article pat, email links were mentioned also, if you want to talk directly to someone.
GTAlover
Sep 19, 2001 09:03 PM
Timmys88Z
Aug 1, 2001 12:21 PM
