weird ignition probs?
Old Mar 12, 2001 | 04:20 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I'm not sure what I did, or what happened, but after digging out the car after a brief winter storage (2 months of sitting) I fired it up with an ignition miss, like I have a plug wire crossed, which I dont, the wires are new, cap is new, rotor, control unit are new, spark plugs are new. It lacks power and changes to the timing has little or no effect on how it runs.
Secondly, when I got shut the car off, the engine will continue to run (as if the ignition is still on) for a few seconds then it shuts off normally. not the normal deisel run on.
could these two problems be related?
Old Mar 12, 2001 | 07:09 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
anyone??
Old Mar 12, 2001 | 07:21 PM
cruise12's Avatar
Car: 2000 Camaro SS
Engine: LS1 V8
Transmission: 6 Speed
Dude, I had the same problem about 2 months ago. Once the car started I had to power brake it like crazy to get just 1 block. Then taking the key out should have turned off th car and in your case as well it didn't.
It turns out that the actual distibuter was rusted and BAD, basically...had to be rebuilt. So I rebuilt it, changed the ignition module also and after that, the car worked mint. Try checking your new cap and rotor, maybe something there isn't right.
Otherwise...your going to have to check the distributer, keep us posted.
John
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
