cant decide between 2 heads!
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
I can't decide between the World Sportsman II's cast 202/160 64cc or Holley aluminum 202/160 63cc. Can anyone help me out. I've got what's in my sig + .040 over and 282* .465" cam. I'm buying them next week and can't decide. I cant either one for the same price.
Thanks guys,
Christopher
Thanks guys,
Christopher
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Since it looks like both flow very similiar, I would also lean towards the aluminum head. They are lighter, less detonation prone, and easier to repair.
Car: 91 RS
Engine: 305 Tbi (L03)
Since you have to put two heads on why not just go with one of each.
On the more serious side youd be better of with hollys for the reasons metioned above.
Engine: 383 Stroker
Car: 91 RS
Hmm that gives me an idea. Since you can only build an engine for one rpm range i wonder what would happen if you built half the engine for high rpm hp and the other half for low rpm torque. That would be one hell of a crazy intake manifold.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Try it and tell us the results!!!
Transmission: 4L80E/4L80E
Car: 89 Formula 350
Engine: 409 nitrous' small block
I'm running a set of Holley heads, I really like 'em.
As for building half and half motor, sounds like you'd pretty much end up with a 4 cylinder for the whole rpm range.
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
