2.8 tbi hestiates, dies?
Old Apr 25, 2004 | 06:32 PM
Wezzeles's Avatar
Car: Camaro
I'm using my buddies sn here
I have an 86 2-10 truck, it's a 2.8 tbi, now it starts up fine, sometimes i give a bit of gas and it responds fine, then other time it will kind of missfire, buck. Mostly it has problems when i'm at like 1/4 throttle and when decelerate, it is really hard to brake, like i'm losing vacume, engine doesn't sound too good either, then after a few seconds idling it calms down and i have regular brake pedal feel. I've just done all the brakes, fuel filter, plugs, igniton wires, pulled back the timming a little ( the proper way with the wire pulled) and tightened up and richneded a little the tps sensor which was loose, water temp sensor the basics. I haven't found any vacume leaks haven't look too too hard, it idles fine, this is a recently rebuilt enine from the guy i bought.
I think it is fuel pump or egr valve/ solenoid, it does tend to get a little hot, but i know the rad is ****ty and replacing that, what does it sound like to you guys???
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Zane Story
Oct 8, 2015 12:40 PM
89bird2.8
Sep 18, 2015 07:46 PM
