Who has a solid lifter cam
Old Apr 26, 2004 | 06:35 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
There is some member on this board who has a comp cam 294* magnum solid lifter cam with .525 on both sides...and a powerband of 2500-6500....I need to know what size stall to use with this cam cause i have one sitting in my room and I reallly want to use it rather than use a hydraulic extreme energy cam...
Old Apr 26, 2004 | 11:33 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you tried going to Comps website and looking it up? I go there many times to look up recommended stalls. It isnt that difficult.
Old Apr 26, 2004 | 04:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you're using a th350 trans you'd want to get a 10" 3500 stall converter for this cam.
if you really want to maximize the launch then try advancing to cam further than the cam card calls for.
dial it in at a 102/103 degree intake c/L. Out of the box is 106.
its all in the details.
Old Apr 26, 2004 | 07:30 PM
EvilCartman's Avatar
Car: '82 Z28
I'm running the 294 but only have a 9.5" 3,000 stall. Might get it changed but so far, it seems to do pretty good. Haven't been to the track yet but hopefully soon since a 9 inch rear is going in.
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
