Manifolds, LT1 vs LT4
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
How is it that LT4 intake manifolds differ form LT1 equivilents? I read something about the ports being 0.01 inch higher, is this the only difference? If I removed that much material from the top of the intake ports on an LT1 head would it bolt right up?
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
The lt4 intake is not an upgrade over the stock lt1. Its just powder coated red and made to fit on top of the lt4 heads. There is no performance gain from the lt4 intake.
Car: '82 Z28
Engine: 350HO
Transmission: M4
Actually it is said that the LT4 intake does flow better than the LT1. But regardless, no you won't be able to install the LT4 intake to your LT1 heads. Don't try. The port shape is just not the same. And i don't think your going to be able to machine it the same.
Car: '82 Z28
Engine: 350HO
Transmission: M4
Originally posted by N8MAN1068
right. the lt4 is D ports
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The LT4 instake is .1" tall on the port size. The only reason for going with one is to say you have a full LT4 top end. You find it hard to get better performance out of the stock LT1 intake. You can port match the intake ports and have just about the best intake out there.
What Shifty said. The LT-4 intake/heads have an intake port roof that is slightly taller than an LT-1. Can't mix-n-match becuase the ports won't line up properly.
FYI- the intake ports and chambers on an LT-4 head are very very similar to a set of iron Vortec heads. The LT-1 heads (and matching intake) intake have ports that are just about the same size and shape as earlier small block Chevy heads (like the old TPI heads, etc.) but they have better chambers. The LT-4 heads (which were designed later) got the better chambers AND better ports. Technology marches on.
Thanks all. I wasn't looking for a boost in performance, its jsut that I need a carb manifold for an lt1 and an lt4 version came along at the right price, but if it won't fit it wont fit.
sailtexas186548
Feb 17, 2017 03:07 PM
