Broken distrib gear teeth
Old Apr 27, 2004 | 04:42 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Take a look at the attached pic, this is my distrib gear after about ~3000 miles. This SHOULD be a gear for roller cams, metaloized(sp?) I believe. The broken teeth seem to be from the high wear, but why did it wear so fast? My only guess is too soft of a gear, I though I found the correct part numbers from this board. I did a quick visual of the cam gear and it looks ok, but is it ok?
Old Apr 27, 2004 | 04:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of oil pump is in the motor? (part # would be great) What oil has been in it? (mfr & viscosity)
Old Apr 27, 2004 | 06:04 PM
I am running a Melling M-55 with Mr. Gasket high pressure spring, ARP oil pump driveshaft, and mobil 10w30 dyno oil.
Old Apr 27, 2004 | 07:29 PM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
I'd like to know myself,I've got the same gear and pump W/GM roller cam.
Old Apr 27, 2004 | 08:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
After image processing it so that I can actually see it, it almost looks like you have a gear for a .500" shaft that's been running on a .437" shaft.
Old Apr 27, 2004 | 09:13 PM
I think you are exactly right RB, ID on the gear's hole is .5. Looks like I need to do some better research. This rebuild has unfortunately seen a steady amount of shavings in the oil.
Old Apr 28, 2004 | 01:12 AM
Not trying to hijack the post, just want to make sure I'm not doing the same thing.
So what your saying is that there are differant size dist. shafts?
I would really like to know before I start this thing.
I'm got an 84 CC dist. and I ordered the melonized gear from SDPC.
Thanks,Don
Old Apr 28, 2004 | 06:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/catalog/251.html Look through all the Chevy listings
Old Apr 28, 2004 | 07:42 AM
Thanks RB!
Old Apr 29, 2004 | 11:39 PM
89 CamaroIROCZ's Avatar
RB that was above and beyond the call of duty. Awesome job!
Matt
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
snakeshooter
Sep 7, 2015 11:15 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
