Which sensor is bad?
Old Mar 14, 2001 | 10:55 AM
2ManyWants's Avatar
Alright, I had this problem before I put my car in storage last year and I better fix it before I take it out this year if the snow ever goes away around here.
Anyway, my fan isn't going on when the temp goes up, but it will go on if I turn on the heat or A/C. I thought it would be the coolant sensor, but I changed that and the fan still doesn't kick in though. I changed the sensor by the thermostat - was this the correct one? I know someone mentioned something about a sensor between 2 of the cylinders on the passenger side of the car - is there another one over there that may be causing this problem?
Anyone have any ideas?
Chad
92 RS
Old Mar 14, 2001 | 11:35 AM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Chad, the sensor you replaced is the temp sensor for the computer. The fan sensor is between the #6 and #8 sparkplugs, right beside the oil dipstick. It's a little buried in there, so you'll have to feel around for it. It's got a connector that you have to squeeze at the sides to release. Before you dump the coolant to change it, test for a bad fan relay. With the engine running, use a piece of wire to jump the pin in the center of the wire's connector to a good ground and see if the fan comes on. If it does, replace the sensor. If you're running a lower thermostat I suggest a Jet fan switch that comes on around 195. If the fan still won't kick on then your relay probably $hit the bed. Driver's side, firewall, in the engine bay.
DR Stevens
Car #1:
1984 TransAm
305 HO (L69)
750 cfm Q-Jet reman. by Holley
K&N filter
700R4/Superior shift-kit
3.42 lim.slip
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel /w/ hood louver
3" exhaust of some sort
partial emissions delete
Car #2:
1991 Firebird/Formula
305 TBI (LO3)
K&N air filter
Hypertech Thermomaster Chip
more in the near future
bryanwood74
Sep 24, 2015 09:50 PM
GTAman
Sep 21, 2015 09:57 AM
86iroczwv
Sep 3, 2015 06:21 PM
squiggy2
Aug 9, 2015 09:30 PM
