230-240 Car Almost overheating WHY?
Car: 99 Formula
Axle/Gears: 342
It is 60 degrees out today, not that hot. I have a 160thermostat. Stock radiator w/tranny cooler. I don't have an electrical fan. The motor is fairly new 1k miles on it. The fluids are filled along w/ the overfill container. Any ideas why it is running so hot. This is when I sit in traffic.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
it might be the sensor that turns on the fan. If the fan sensor is broken, then your engine will heat up, and when the sensor is suppost to tell the engine fan to come on, it isn't becuase it's broken, causing the engine to overheat.
He doesn't have an electric fan. I'm assuming you flushed the radiator before you dropped in the new engine, so what kind of mechanical fan are you running? Mine heats up fast as hell too in traffic, but not with the new 200*F fan switch and 180 t-stat. Your cooling system is probably just less than adequate and a new engine will generate more heat than one that's been around for awhile. I would wire in a flex-a-lite fan or something with an adjustable thermostat so you can set it to suit you. One more thing, the air dam is till on the car, right? Other things to check, collapsed hose, radiator cap, maybe the water pump but I'd say yours is new. Hope this helps.
Car: 88 Firebird WS6
The goodwrench doesn't come with a water pump. Is it possible that you got a water pump for a tpi that has a serpentine setup with reverse rotation??? You say you don't have an electric fan, so you must have v-belts then (assuming) which rotate the water pump conventionally.
Just something to check.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
This may sound stupid but my Trans Am kept overheating last summer and I have a 160 thermostat which was new and working. After replacing misc. sensors and relays I found that my Radiator Cap wasn't holding pressure. I replaced it and everything is fine now. Try replacing it, it's not expense and probably needs it away. Good luck!
'87 Trans Am
305 TPI:
160 Degree Theremostat
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Spark Plugs
Custom Ram Air with K&N
'87 Trans Am
305 TPI:
Accel Super Coil
Bosch Spark Plugs
Car: 99 Formula
Axle/Gears: 342
I am using the water pump off of my 305. Could that be my problem, the car usually runs at 180 while driving. I am not sure what kind of fan it is I would guess a flex a lite, it's red and turns when ever the motor is running. Maybe I will try a new cap, I believe my brother put that on so I know it isn't knew.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Car: 99 Formula
Axle/Gears: 342
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Car: 99 Formula
Axle/Gears: 342
Oh, and what is an air dam?
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Mark,
Make sure the coolant flow is adequate. Even if there is flow visible in the radiator tank, it may not be adequate to cool the engine. A worn pump or restricted lower hose can contribute to poor flow, as well as excessive corrosion in the system.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Later,
Vader
Car: 82 camaro SC
Air dam won't do much around town--it forces air up into the radiator when the car is moving. Thermostat won't make a difference at that temp. Running a carb with an open element probably doesn't help, especially when you are stopped.
Make sure the fan is in good condition.
Make sure the idle speed is high enough to spin the fan fast enough.
Make sure the idle mixture is optimum--to lean can make the engine run hotter.
Timing, Timing, Timing--make sure you have the timing set properly. Too much timing at idle can make it run hotter.
Make sure you don't have any air in the cooling system.
305/350 water pumps are usually the same part number.
Underdrive pully's spin everything slower to save HP(water pump/fan)
Lots of stuff can cause you car to overheat, the above stuff is just what I could think of right now. I running a flex fan on my 350 and it runs 190 around town, so you don't 'need' an electric fan.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
you do have a fan shroud on it to direct air flow? Yes/No?
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Car: 99 Formula
Axle/Gears: 342
Actually I don't have a fan shroud which isn't helping, the fan sticks over the radiator.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Car: 2002 SOM z28
Sounds like a combination of things: no fan shroud (being the biggest IMO), underdrive pulley (being the second), old radiator/pump, and possible timing too advanced may be the biggest culprits.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Linson
Aug 21, 2015 02:12 PM
