CODE 32! Experts Needed!
Old Apr 27, 2004 | 08:47 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
Ok, here goes. The motor is a '89 LO3 w/ 67k. I have added true dual exhaust to it a while back and ever since have had a CEL on the highway. The exhaust has duals cats and mufflers. My egr valve is working properly.
The solenoid needs a few things like coolant temp, tps, ecm control etc in order to ground the solenoid and have vacuum enter the egr valve.
I'm assuming the problem is the lack of backpressure to the easier flowing exhaust. So i got to thinking and i installed a '96 LT1 Camaro EGR valve. It worked for one day and then i got the code again. Another valve i could try is the 96 Camaro 5-speed egr valve since it was made for an even lesser restrictive exhaust.
Anybody have anything to add? I'm kinda stuck and I can't really find an actual solution. Thanks,
Adam
Old Apr 27, 2004 | 08:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't know what type of back pressure the LT1 EGR valve uses, but the 89 LO3 EGR valve uses negative back pressure if I remember correctly.
Old Apr 27, 2004 | 10:19 PM
Car: Caprice
Engine: 5.0 305 LO3
I was told by another guy that it uses positive and that i should try switching to a negative one.
Old Apr 27, 2004 | 10:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I saw your other post and the gentleman is correct, you should be using a negative back pressure EGR valve. It is identified by the letter "N" in the P/N or the letter "N" stamped on it.
Old Apr 27, 2004 | 10:54 PM
Car: Caprice
Engine: 5.0 305 LO3
Ok, now when you say should be, do you mean stock or now that i have modified exhaust?
Old Apr 27, 2004 | 11:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The negative back pressure EGR is what came on the stock engine, your modified exhaust may require a positive or ported EGR valve. I have little experience with a modified exhaust like yours, so I can not give you a definitive answer
Old Apr 27, 2004 | 11:07 PM
Car: Caprice
Engine: 5.0 305 LO3
No, i have a positive backpressure egr valve stock. He was suggesting using a negative one.
Old Apr 27, 2004 | 11:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
My bad, I just noticed in your profile that you have a caprice. The information that I have been giving you is for a camaro, trans-am, or firebird.
lee01
Apr 9, 2016 01:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
