Hypertech fan switch
Old Mar 14, 2001 | 06:07 PM
JETHROIROC's Avatar
What gives with that little connector they sent with the switch? Mine just plugged right in without it.
Old Mar 14, 2001 | 06:12 PM
ede's Avatar
ede
then you don't have a problem right? i put one on my l98 iroc and had to use butt type crimp connectors
ICON Motorsports
1st & 3rd
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Mine, too - just another spare part lying around my garage...
KAM
Old Mar 14, 2001 | 06:14 PM
JETHROIROC's Avatar
Ahhh. Thanks guys. That's what I figured but I wanted to be sure since the one they sent is nicer than stock.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat,
Hypertech fan switch, hot wife, new oil filter,
thick rubber floormats.
18.0 @ 85MPH since I'm one big-a$$ MF
Old Mar 14, 2001 | 09:13 PM
nFORM91's Avatar
Hi guys, excuse me for asking this dumb question, but what advantage is there for using a Hypertech fan switch? Just wanted to know. Thanks.
nFORM91
Proud newly acquired '91 Formula 305 TPI 700R4, 34K miles, Factory Black on Black all stock - no current HP mods (might keep that way!). Rims are '91 T/A black Diamond Spoke 16x8s. 20% tint & Black Widow Alarm system. Very near future plans: K&N filter, catback Flows, fresh paint job, new 255ZRs all around.
Old Mar 14, 2001 | 09:56 PM
Vader's Avatar
nFORM,
On some cars, replacing the secondary fan switch can result in a lower fan cut-in temperature. This is a logical step in cases where the thermostat has been changed to something rated below the 195°F stock unit.
If your car has a dual electric fan system, you might want to explore the benfits of a cooler than stock thermostat and lower temperature fan control. Even if you have a singlew electric fan, or an older car with a clutch fan, you can still benefit from a lower coolant temperature. Search the tech Articles and message archives for some of the reasons, then decide.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
