Fuel pump won't turn off?
Old Apr 29, 2004 | 12:24 AM
CrazyHawaiian's Avatar
Car: too many ...
I tried a search but couldnt find an answer. When I turn my 89 IROC off (all stock everything, L98 TPI) the fuel pump does not turn off. I can hear that the pump is still on. If I turn the car on again, and then turn it off again the pump turns off sometimes. If not, I unplug the battery and it turns off (of course haha). The car exhibits no abnormal driving conditions, starts fine, runs fine. Do you guys think the fuel pump staying on is an indication that it is on its way out? Or a possible electrical issue somewhere in the car? Car has 114k miles and the fuel pump looks like the OEM unit. Trying to prepare for a problem before it happens hehe. Thanks for any info you guys might have.
Old Apr 29, 2004 | 12:37 AM
AM Racer's Avatar
The only way a pump can remain on is if the power doesn't shut down with the key.
Sounds like a relay sticking on.
Old Apr 29, 2004 | 02:11 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Unplug the relay, see if it quits. If it doesn't then the oil pressure switch is sticking.
Search for a diagram and you'll see. They are available.
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227165/
Old Apr 29, 2004 | 02:54 AM
Car: too many ...
Thanks guys!!! Really appreciate the help!!
Old Mar 6, 2005 | 10:25 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You ever figure this problem out? Mine just started doing it with the new engine.. Well actually, I was cranking the motor over by shorting the solenoid (ford solenoid) and the pump would kick on (key out of ignition) I don't see how thats possible with the ignition turned off, because those relays should not be energized at all..
-- Joe
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
