Angle plug heads ?
Old Mar 14, 2001 | 01:50 AM
Blade's Avatar
Angle plug heads ?
Hey all. I just found out the trick flow 23 degree heads have angle plugs. Does anyone run these heads with Edelbrock headers ? I'm worried they wont fit and I might have to get some really short plugs.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Mar 14, 2001 | 04:05 PM
Blade's Avatar
btt
Old Mar 14, 2001 | 10:12 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I think the new design angle plugs have quite a bit less angle than the originals.
In most cases, they fit with 90 degree boots and in some cases short plugs. I had the 1 3/4 inch hooker supercomps on a set of Track1s with angle plugs (and they really have some angles), and the #3 hole was the only real close one.
normally, the problem comes when you try to change plugs. A socket will not fit on most combinations and you end up using a 5/8 or 13/16 boxend.
[This message has been edited by jcb999 (edited March 14, 2001).]
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
