Mechanical Fuel Pump Tapping
Old Apr 29, 2004 | 10:53 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
I guess this means it's going to tear up soon. Anyone else had this problem???
Old Apr 29, 2004 | 10:54 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How do you know its the mech. fuel pump that is making that noise? have you, per RB's favorite suggestion, stuck a piece of heater hose in your ear and listened to it and confirmed that it is indeed the pump?
Old Apr 29, 2004 | 10:55 AM
Car: '87 Camaro SC
Engine: 305 LG4
That's exactly what I did...finally found the noise yesterday.
Old Apr 29, 2004 | 10:59 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Well, if you are certain thats what it is, i would just go to the parts store and ask for a replacement. I think delco makes a pump.
What part of the pump is it coming from?
Old Apr 29, 2004 | 11:06 AM
Car: '87 Camaro SC
Engine: 305 LG4
It's seems to be coming from the top, but I could be wrong...never had one make this noise before. I thought it was going to be the timing chain but the noise is coming from the pump. I would much rather replace the fuel pump though!!!
Old Apr 29, 2004 | 01:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely the spring has taken a set so it isn't as long as it should be. No reason to think it is going to "tear up soon", although it might be marginal at higher RPMs.
I had a brand new pump make noise. The engine sounded like an Olds diesel. It was a bad spring.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
