Not playing favorites. But, VADER check this out.....
I disconnect the brown and black wire to set timing and plug it back afterwards and it cuts out at half throttle. But when I leave it disconnected it will go to full throttle with a slight misfire but it runs better. What do I replace I believe you called it the EST right? Where is it and is it necessary? THANKS
lol, I said I'
m not playing favorites man! answer it if you know
He helped me with this the other night and I just figured he would have a little advantage by having backround on the problem at hand. I need all of you guy's BELIEVE ME
He helped me with this the other night and I just figured he would have a little advantage by having backround on the problem at hand. I need all of you guy's BELIEVE ME Thread
