Rusty/stuck intake bolts on TPI
Old Apr 30, 2004 | 02:20 PM
92 Rag's Avatar
5L TPI, I'm changing intake gasket - I've got all the intake torx screws out except the 2 front pass side ones. they must rusted right in,the others all came out easily.
I've broke off a 45 torx already, what's the easiest way to get those out? I've heated them as well with a propane torch, and sprayed lots of penetrating oil down there too.
Any help would be appreciated, and what other intake-change tips do you have while I'm at it?
Thanx, Scott
Old Apr 30, 2004 | 02:36 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
here is my little secret trick for getting those...I tack weld a nut on top of the bolt head and then use a socket or a wrench...Works every time. it is siezed because the corrosion that happens between the steel bolt and the aluminum intake...The bolt is actually siezed in your intake, not the head.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
