oiling is a problem!!
Old Mar 15, 2001 | 11:44 PM
burnoutrpm's Avatar
i was wondering how can you tell if your oil pump is sucking the oil pan dry??? i just finished the mods in my signature and now my engine runs hot, has a wierd unexpalinable smell, and only hols 30psi on the highway!! and at idle it holds a cool 10psi!! i have a stock oilpan and a melling high volume,high pressure pump and im cooling the engine witha 31"x19" griffin dual 1" core all-aluminum radiator! the engine has been tested for fuel pressure (its not
leaning out at high rpms!!) also the total igintion timing is 36 degrees. so you guys think its rinning dry??? im also running 10w30 wieght oil(castrol gtx)convental oil. the engine has 16" of vacuum,no leaks in the oilpan or gasket.
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
[This message has been edited by burnoutrpm (edited March 15, 2001).]
Old Mar 15, 2001 | 11:48 PM
mtx28's Avatar
there could possibly be a plug somewhere in the oil passages, blocking the oil somewhat and leaving you with limited pressure? have you checked the oil level with the engine running? are you sure you have enough oil in it? as for fuel, is it the stock unit? and do you think the fuel filter is plugged, not letting enough fuel flow at high rpm's, but will let it flow enough at lower ranges?
  • 83 Z28--ttops, 200k miles--very ragged out. sold after a year of owning it
  • 74 Z28--slightly modded 383, TH400 tranny, 10 bolt rear, not to swift, but a 700R4 and EFI is on the way
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
