what should I set my timing at?
Old Mar 15, 2001 | 02:13 PM
chris1roc's Avatar
what is good for the mods that I have?
88 iroc
LB9 305 tpi
k, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 15, 2001 | 02:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
6, 8 or 10 degrees, and always use 92 octane or better. You should set the timing at whichever level gives you no knock or ping.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 17, 2001 | 12:08 AM
MouseCamaro305's Avatar
actually chris, l think you should keep the timing where it's factory setting, somewhere like 6 degrees advanced l beleive, if you change the timing, its going to require more octane, its going to be a little bit rougher on the motor itself, and its gonna be a little rough on the computer, and you won't actually notice a difference, not to mention youre going to get a slight drop in fuel economy, after adjusting the timing, the car may run decent for a few days, but it will stutter, and run rough after time, your best bet is to leave the timing at stock settings and instead, buy a good chip for your 305, youll actually notice a difference with the chip
good luck
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
