timing help
Old May 4, 2004 | 01:00 PM
pskel350's Avatar
timing help
what do you guys like to set timing at on a carb'd engine?
i have been setting mine 8* with the vaccum advance off and plugged. after i plug it back in, the timing jumps up to 22*, and is at about 34* @3000rpm. is this normal?
i have a 350 with a mild cam, and a 650 holley. the vaccum gauge says the engine is making 15" of vaccum.
should the timing jump up that much at idle?
Old May 4, 2004 | 01:19 PM
ede's Avatar
ede
pretty much normal, the vacuum is pulling at idle and making the timing advance. if you had no vacuum to it at idle it's stay where ever you set the base timing at.
Old May 4, 2004 | 01:49 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
sounds like you have your vacuum advance plugged into "manifold vaccum", it should be plugged into a vacuum port ABOVE the throttle valves. there should be no vacuum adavance at idle speeds. On holley carbs, the port your looking for is the highest one on the carb.
set up a vaccum guage to manifold vacuum, and turn the distributor until max vacuum is acheived, with the advance un plugged. which is around 8-12 degrees on a typical SBC. total advance should be around 36 all in at about 3200. thats with the vaccum advance unplugged. of couurse, every combo is different
Old May 4, 2004 | 10:06 PM
pskel350's Avatar
well i've heard two different answers from many different people now. some say that i should have no vaccum advance at idle, and some say 22* at idle is fine
does any one know for sure?
Old May 5, 2004 | 04:30 AM
ede's Avatar
ede
either will work, depends on how you want it set up. most street applications will see no vacuum at idle to the vac advance. it all depends on how quickly you want to get to full advance.
Old May 5, 2004 | 10:34 AM
pskel350's Avatar
ahh ok, so there isnt a right and a wrong way, just different ways todo it.
thanks ede!
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
