Eradic idle
Old May 4, 2004 | 01:04 PM
I_ROC U_ROC's Avatar
Car: 90 Iroc
Engine: 5.7 TPI
Eradic idle
just bought a 90 iroc,5.7,tpi,auto. It ran rather rough so I tuned it up this weekend plugs,wires,pcv,cap,roter. k&n air filter on order. It runs much better. After it has warmed up than you come to a stop and it idles in drive or OD the idle is eradic, from 450 to 650 rpm. Put it in neutral or park than nice and smooth. Its only after the car is warm, it runs great and idles smooth b4 its up to temp. HELP
Old May 5, 2004 | 08:40 PM
Vader's Avatar
Did you clean the TB and IAC air passages as part of the tune up?
If you can check fuel pressure, make sure it is adequate.
If the oxtgen sensor is more than 30,000 miles old, you might want to check the signal from that as well.
Make sure there are no vacuum leaks. That includes the hoses, brake booster, EGR valve, injector 'O' rings, and gaskets.
Old May 6, 2004 | 09:16 AM
Car: 90 Iroc
Engine: 5.7 TPI
thanks I will try that. what would explain why it idles perfect in warm up, and perfect in neutral or park. Its only in drive when the idle gets eradic.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
