Infernal Vibration
Old Mar 17, 2001 | 07:55 PM
Quiet Bob's Avatar
Infernal Vibration
This is a great site. Remedied a lot of propblems by reading here every day. So, I've got an '87 Iroc, TPI 350/TH350, with what appears to be the OEM driveshaft. I have a vibration, or an oscillation, which begins at 2000 RPM, and the frequency of the oscillation increases with increased RPM. At 100 MPH, it's no longer oscillating, but, is one constant growl of a vibration. The mirrors even blur like those on my Harley! Any idea's/thoughts/opinions??? By the way, the vibration begins at 2000 RPM regardless of what gear it is in.
Old Mar 17, 2001 | 08:00 PM
ede's Avatar
ede
have you checked anything or you want us to trouble shoot it for you? might be a good thing if you checked the u joints, trans and motor mounts, wheel/tire balance,and the drive shaft straight.
ICON Motorsports
1st & 3rd
Old Mar 17, 2001 | 08:08 PM
Quiet Bob's Avatar
U-joints seem OK (no movement up & down Nor Back & forth). Transmission mount is new Energy Suspension. Don't know about wheel\tire balance, but will spend time at the local Big O and find out. Don't know about motor mounts yet.
Old Mar 17, 2001 | 08:21 PM
ede's Avatar
ede
might want to take a look at the crank dampner too, make sure it's not coming off. how is the th350 mounted? does it have a adapter kit such as b&m pn 30299? if the trans isn't installed and mounted correctly there may be a problem. cracked flex plate makes lot of noise, look at the torque coverter bolts too.
ICON Motorsports
1st & 3rd
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
