VSS questions
Old May 4, 2004 | 05:39 PM
pat12spe's Avatar
VSS questions
Ok, here's the setup. I'm stuck in the middle of a tpi swap from my 91 TBI to speed density TPI. I'm trying to figure out what to do with the VSS portion. I know all TBI's VSS signal is 2000 pulses per mile and the 90-92 TPI's are 4000 pulses per mile. What can I do? Can I just swap the vehicle speed sensors out or would I have to get a dakota box with buffer? Is there anyway I could just ditch the speed density and go with MAF? I'd like to know all my options here, so if there is anything that can be done to have a properly working TPI please let me know. Thanks.
Old May 5, 2004 | 12:52 AM
onebinky's Avatar
When you grab everything from the donor car, just grab the VSS with it. GM puts it right on the side of the tailshaft, so it's pretty easy to change. The driven gear should be interchangable between the two VSS also.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
