Need help with heater core!
Old May 5, 2004 | 02:00 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
I am attempting to replace the heater core in my 87 GTA myself. I am not completely clueless, but I want to know what the easiest way to go about this is. Any help would be much appreciated.
Old May 5, 2004 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends upon how you define "easy".
Easiest for the actual removal and reinstallation of the core is to remove the dash.
Easiest for least parts taken off is to leave the dash in place and play contortionist.
Easiest overall is probably somewhere in the middle. Remove dash pad, loosen but not completely remove the dash and hold it up out of your way with bungie cords, R&R the core.
Old May 5, 2004 | 02:36 PM
Ian_F's Avatar
Engine: 4.0
now how exactly do I remove the dash and all that?
Old May 5, 2004 | 10:37 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Lotsa bolts and screws and cussing.
Look at this, it should give you some idea of how to change it http://www.hioutput.com/tech/heatercore.html
Old May 5, 2004 | 10:58 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah i've had to do it twice in my car unfortunately...but i think the second time it was something else and i was just being paranoid
but anyway...to get the top bolt on the cover that houses the heater core i remember taking A LOT of different extensions and rigging up 2-3 foot extension that had just enough flex where i could squeeze it up in there and get to it just perfectly.....good luck
Old May 6, 2004 | 01:17 AM
Ian_F's Avatar
Engine: 4.0
Thanks for all the help, I'll tear into it more tomorrow morning.
Old May 6, 2004 | 09:29 AM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
I just did this a couple months ago . The best piece of advice was taking out the passenger seat gave my 6'-2" frame lots of room to work with. It took me a little over 2 hrs to replace the heater core and reassemble everything. Granted this was on a 1992. For that last screw which is the only pain in the but item in the entire job. I removed partial of the upper dash . Then I loosened a white box thats about the size of 3" x 5" slid that down , took a 10" extension and a 4" extension and undid the screw. Its not really as hard as its made to sound just take your time and it should come out quite easy
Dynodan
Old May 6, 2004 | 10:40 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
It took me 30 minutes to change the heater core on my 91 GTA... The only parts you have to take off are the bottom plastic cover on the passenger side... Then, using one of those flexible nut drivers (how did I live without this little guy before?!), you can get all of the little screws out (yes, even that top one) fairly easily... Hardest part of the entire project is separating the hoses from the core in the engine compartment (if they've been on there forever)..
Old May 6, 2004 | 03:45 PM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
I was able to get those hoses off ina jiff I just crushed the old cores tube with pliers slip right off.
Dynodan
Old Nov 16, 2004 | 06:08 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Dynodan
what is that white box? would an 86 have it too? so you can see that top screw from under the dash pad?
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
