Tv Cable adjustment, everyone thats delt with it
Old Mar 17, 2001 | 11:47 PM
FiReBReTHa's Avatar
ok, i just did it, (somwhat friend had got to it first)
now someone told me that i wasnt supposed to do that, can you guys explain this thing a bit?
Thanx!
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Mar 18, 2001 | 12:31 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
The tv (or detent, or kickdown) cable is connected to the throttle by the carb or intake. It pulls on a clip inside the transmission for it to downshift when you get on the gas hard. I dont know much about how it works exactly, but thats the general idea.
Old Mar 18, 2001 | 04:18 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
There's a right way and a wrong way to adjust the TV cable. To do it correctly you need two people. Press in the square button on the throttle cable and hold it in while a friend pushes the accelerator pedal all the way to the floor. The cable will click into place.
The wrong way to do it is to just push in the button and pull the cable tighter (toward the firewall) This will make the car shift at a higher rpm, no matter what throttle you're at. It also may shift at higher rpm at full throttle, and in the redline if you're not careful. I've heard that adjusting the TV cable this way can be bad for the tranny, although I'm not sure if it's true. This is probably why you heard that you're not supposed to do it.
Old Mar 18, 2001 | 10:16 AM
FiReBReTHa's Avatar
dam,
ok, i already did it, i just feel a crap load more power, dam.
Old Mar 18, 2001 | 12:20 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ViciousZ:
</font>
so you are saying that the tech article on sethirdgen.com is the wrong way to do it??
Old Mar 18, 2001 | 12:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I might add, you should open the throttle to WOT, from the linkage at the TB, not the pedal...carpet and floor mats may inetrfere with full WOT, if this happens, then line pressures will not be correct for the shift points.
Old Mar 18, 2001 | 02:52 PM
FiReBReTHa's Avatar
WOOHOO!!
score.... yea theres a tech article here on thirdgen.org
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
