305 rebuild...how to get started
Old May 6, 2004 | 08:12 AM
dp149's Avatar
Okay, I recently got an entire 305 engine complete from q-jet carb to oil pan from an 85 iroc (LG4). I have an 86 ta with the same engine which is about to go south. I want to rebuild this engine myself and I have some experience (but no expert). I want to keep it stock (I know everyone will yell performance but I am ok with how the current engine takes care of me). General questions to all you engine rebuilding experts:
1) As I take it apart, any special problem signs to look for?
2) Any special books recommended for the 305 rebuild process?
3) Anything that needs replacing right off the bat? car had 95K original miles.
Thanks for any and all help...I am in no hurry, I just want to do it right....
Thanks alot.
Dean
Old May 6, 2004 | 09:12 AM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Timing chain?
Old May 6, 2004 | 05:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What engine are you taking apart? if you are taking apart the engine that will eventually end up in your car, i would strip it bare and inspect every last inch of it. It would also probably be benificial to take it in and have it checked and machined if needed.
If the crankshaft has developed any form of surface rust, i would take care of that, as well. Investing in a Summit rebuild kit or equivalent would be a good idea. Get the bearings that match the crankshaft (if the crank had to be ground, get the proper size. Same thing with overboring)
I guess from here, it really depends on what parts you want to reuse and what parts to wish to replace.
Old May 6, 2004 | 05:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Suggestion: Put the '85 engine in the car as-is. Get it running.
Then rebuild the '86 engine. If you really want to rebuild one, that is. It's a slightly better engine than the '85 (but only slightly, I suppose).
Better idea would be to put the '85 engine in the car as-is, then go get a builder 350.
Jake_92RS
Jan 28, 2020 10:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
