??'s about base timing
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I've done some research about base timing, particularly in a haynes manual (yeah, I know.) I was hoping someone could use layman's terms in describing it and how to establish it. Also what did you set it to with your aftermarket cam? Thanks.
Transmission: 4L80E/4L80E
It's the timing the distributor is set to without the computer getting into the act. The "basis" upon which the computer then adds advance with varying engine/vehicle conditions.
Start where it was for the stock cam. Run it. Advance it 2 degrees. Run it some more and compare to previous. Continue until you find the place were it starts running worse, then put it back to the place where it ran best.
